hy i have a problem with my modem I was doing the update but unfortunately as soon as it had finished the light went out and unfortunately now the modem turns on but nothing appears on the mini monitor anymore it is possible to solve this problem because I can not do anything even a software reset let me know thanks
(03-23-2019, 09:00 PM)admin Wrote: It uses 5v, with an average of about 77mA of current.
Threads: 135
The modem should work as normal after the update. You do have to power off and then back on after the update is complete.
Can you enter modem commands? You could try going backwards in firmware by typing: AT*DOWNGRADE <RETURN>
(09-15-2021, 01:36 PM)admin Wrote: The modem should work as normal after the update. You do have to power off and then back on after the update is complete.
no sorry the modem not work ...when i put on the c 64 there is only a led blue that lamp a istant but the mini monitor was in off mode and it is not possible use the terminal progran with the at command dont write nothing on terminal program
there is a possibiliti to reset manual the modem ???
Threads: 135
Yes, please see the reset procedure in the manual.
(10-04-2021, 01:59 AM)admin Wrote: Yes, please see the reset procedure in the manual.
sorry i have reset the item manually but nothing change olly led blue lamp and minimonitor nothing ...it is possible send the itam to you for see the problem ???
Threads: 135
Yes, you can return it to check it out. Please see the return information here:
https://www.cbmstuff.com/index.php?route...on/contact
(10-08-2021, 03:21 AM)hy i will send you item please tell me on organza2000@libero.itwhen arrive ok bye thanks admin Wrote: Yes, you can return it to check it out. Please see the return information here:
Threads: 135
please tell me if receive ok thanks
