These few questions may sound obvious, and I apologise if they but I'd appreciate answers.
* The RF modulator. Is it needed, should I fit a de-soldered commodore item removed from a 64 and does it output ~ channel 35 like original commodore 64s?
* The R-L header. Is it intended to connect to a stereo audio jack, should I fit a plug and cable relieving a hole in the RF Modulator shield to get from the header to the case?
* The VIC-II shield. Should I fit it?
I'm waiting on a couple of zenner diodes to drop through my letterbox and I will have finished. I found the ICS64 documentation, build guide and BOMs invaluable and a pleasure to use. They were half the fun of the project.
The RF modulator is not needed - in fact, it won't even fit because the surface mount parts in the way. The only way to use a modulator would be to remove the surface mounted parts. That would be a bit foolish because the ICS64's video output is quite amazing due to the RF modulator replacement circuitry (the surface mounted parts).
The R-L plug is designed for a 3 pin JST plug to a 3.5mm (or similar) stereo jack cable. That can be either mounted to the C64 case or just passed through an opening. You need a stereo SID chip setup, with the extra SID output connected to the extra "L" pad.
(05-05-2022, 01:08 PM)admin Wrote: The RF modulator is not needed - in fact, it won't even fit because the surface mount parts in the way. The only way to use a modulator would be to remove the surface mounted parts. That would be a bit foolish because the ICS64's video output is quite amazing due to the RF modulator replacement circuitry (the surface mounted parts).
You can use the shield or not. Most people don't.
Nice build - it looks great!
Thank you so much for the advice. I have another question; do you know if there is a cool running VR2? Mine gets hot enough to need a heatsink which prevents me from using a C64C case.
