The ICS64S uses a standard SERIAL connection (Rx/Tx/VCC/GND), making it compatible with CP2102 and FTDI USB to serial interfaces.
The flashing software will use a COM port.
A couple questions:
1. Where is the most current firmware available from?
2. Is it open source?
3. What firmware flash utility should be used?
There is no firmware currently available as it has not changed at this point.
No, it is not open source.
I have a flash and settings changer program for the PC. I will put together an archive shortly.
