05-01-2018, 08:52 AM
The WiModem is a modem emulator. If you could use a real modem for whatever you are thinking, you can also use the WiModem.
WiModem Problem
05-01-2018, 11:58 AM
05-01-2018, 01:48 PM
Yes. You can connect the two together by just using their IP addresses.
There is a program called WiBridge that lets you connect your PC to your C64 (or any other WiFi device) and even allows you to browse the PC's hard drive and transfer files remotely. You will find a thread on WiBridge in these forums.
05-01-2018, 02:54 PM
(05-01-2018, 01:48 PM)admin Wrote: Yes. You can connect the two together by just using their IP addresses. hi i have downloaded wibridge and i set the wimodem at&s1 but when i connect the program wibridge to ip of wimodem on c 64 appair ring and after ring and ring on terminal program etc and after if i cant tranfer file or other operation ......... what is the error?? it my error or procedure wrong??please send me the working procedure if you can thanks
05-01-2018, 05:24 PM
You're not setting the right register. Please see the manual for the proper S registers to use.
The S-Reg responsible for the auto-answer is S0. You would use it like this: ATS0=1 {RETURN} This would set the number of rings before answering the connection to 1 ring.
05-02-2018, 01:35 AM
(05-01-2018, 05:24 PM)admin Wrote: You're not setting the right register. Please see the manual for the proper S registers to use. Hello ok now I connected I put a space too much and did not work .......... now tells me connected to monitor and also writes me connected on wimodem ... also writes me c user desktop on c 64 (my persui on pc) .... but now how do I move the files because I tried both with xmodem that with z modem but nothing happens .... I need a program even on c 64 ??? do i have to do it from pc or from commodore 64 ??
05-02-2018, 12:04 PM
Yes, you need a terminal program on the C64 that will handle Xmodem or Zmodem protocols.
05-03-2018, 03:22 AM
05-03-2018, 07:44 AM
(05-03-2018, 03:22 AM)scanword Wrote:(05-02-2018, 12:04 PM)admin Wrote: Yes, you need a terminal program on the C64 that will handle Xmodem or Zmodem protocols. Usage: Run wimodem on your windows machine. It listens on port 6464 so make sure your fiewall doesnt block this on the host machine. Then fire up your favourite terminal program (tested with striketerm and ccgms 2017) , atdt ip.address.of.host:6464 and put the terminal in recieve mode. you can then click Send on the Wibridge and select the required protocol (ZModem and XModem supported) http://home.reidspace.com/index.php?id=c64-stuff
05-04-2018, 04:14 AM
(05-03-2018, 07:44 AM)Zeropage Wrote:(05-03-2018, 03:22 AM)scanword Wrote:(05-02-2018, 12:04 PM)admin Wrote: Yes, you need a terminal program on the C64 that will handle Xmodem or Zmodem protocols. |
« Next Oldest | Next Newest »
