Threads: 13
(04-04-2017, 12:15 PM)Digital Man Wrote: [quote pid='2401' dateline='1491305681']
Version 1.1
Added the ability to browse the pc host using standard DOS commands(DIR,CD <DIRECTORY> etc) from the terminal on the c64.
WARNING! Please be aware that this is a fully blown dos CMD wrapper so it is possible to delete files on the host if you want to do so.
This is awesome! Thank you!
For security, I'd love to be able to lock it down to specific folders.
Great feature.
[/quote]
I was thinking about that ..
I suppose I can restrict it to folders within the current folder to prevent accidiental problems, I just dont know if that might annoy people.
Its not like you can do anything on the c64 that you wouldn't be able to do if you were sitting directly in front of the "Server" machine.
It might be something to consider if you want to host files for other people outside your network I suppose.
Threads: 13
I'm looking at a way to integrate ftp next.
Threads: 6
(04-04-2017, 01:19 PM)Zeropage Wrote: I'm looking at a way to integrate ftp next.
Strange issue for me. When I navigated to a folder somewhere else on the PC to get files that I had prepared, and issued the zget *.* it started downloading Wibridge.exe which is in the folder WiBridge starts in but certainly not the folder I had setup.
....still trying a few things.
Threads: 6
So after a few tests; it appears I can navigate the entire directory structure of my PC but if I use the zget command to download the file MUST exist inside the directory from where I launched Wibridge. Maybe I'm doing something wrong?
Threads: 13
(04-04-2017, 05:15 PM)Digital Man Wrote: So after a few tests; it appears I can navigate the entire directory structure of my PC but if I use the zget command to download the file MUST exist inside the directory from where I launched Wibridge. Maybe I'm doing something wrong?
Sounds like the CurrentDir is being reset .. I'll have a look. Thx for the report.
Are you using windows 10 ?
Threads: 13
Ok, I've uploaded version 1.1.1
It should fix this problem.
Threads: 6
(04-05-2017, 04:27 AM)Zeropage Wrote: Ok, I've uploaded version 1.1.1
BTW - Yes working great now. Thanks. And yes I am on Windows 10. Now.....how do I pump up the speed? 32k? Probably require a special driver or program on the Commodore side.
Threads: 13
(04-06-2017, 06:11 AM)Digital Man Wrote: (04-05-2017, 04:27 AM)Zeropage Wrote: Ok, I've uploaded version 1.1.1
Thx for the feedback.
As for upping the speed, my program will go as fast as the terminal on the c64 side can go. (I actually have to slow it down a bit)
Maybe we can convince some of the low level gurus to have a look at adding the 38k commodoreserver driver to Striketerm .
I can tell you that the PC program, at least for when showing a directory, is throttled to be much slower than 9600 baud. I run 9600 baud all of the time and I am use to how fast it is. You should try a version with no deliberate slow down to see if it can be used with the hardware flow control (AT&K1) and the UP9600 hack, via CCGMS2017.
Threads: 13
(04-06-2017, 08:09 AM)admin Wrote: I can tell you that the PC program, at least for when showing a directory, is throttled to be much slower than 9600 baud. I run 9600 baud all of the time and I am use to how fast it is. You should try a version with no deliberate slow down to see if it can be used with the hardware flow control (AT&K1) and the UP9600 hack, via CCGMS2017.
Yeah, if I send text as fast as possible, it starts dropping characters after it begins scrolling. eventually I decided that stable was better than fast and changed it to sending individual characters with a tiny delay between each character.
The file transfer itself however should be full speed.
I *think* I have rts/cts enabled, but I'll double check and if its not, set it and re-try
