I was able to get a connection(kind of) using Genesis tcp stack and Wimodem232.I get the connect message but no response.I'm using the aslip.device and the config file reads..serial.device 0 57600 10.x.x.x 7wire..am I missing something?..do I need to initialize the modem?This is farther than its ever responded so I know i'm on the right track.Any help would be appreciated.
Genisis stack & Wimodem232
05-31-2021, 08:47 PM
I don’t know anything about setting this up. If the connection uses Telnet then it would require you have Telnet emulation enabled.
The WiModem232 emulates a real modem so if you were to get this working on a real modem then you should be able to just substitute that for the WiModem232. |
« Next Oldest | Next Newest »
