05-19-2020, 05:59 AM
After having bought one of the Compaq external tape drives with the full height 5 1/4" drive bay I had another idea. It all started with a 1541 with the Alps drive that I stole the head from for a friend of a friend. Now that I had this shell what would I do with it?
It occurred to me that with some 3D printed case extensions I might be able to mount a 5.25" and 3.5" drive in the 1541 case. It still uses the metal frame inside which has been modified a bit. The 5.25"-to-3.5" adapter I bought is actually a bit taller than 1-5/8" so I need to mill it down a bit. Ignore the blue painters tape, it is just holding some of the 3D printed parts in place temporarily. I need to adjust the height of the 3D printed parts a bit and print out a new set in something other than black. Or. maybe paint the whole drive black?
Now imagine if the IEC connector on the SCP was working. I could put an IEC DIN socket on the back and use it as a dual 1541/1581 drive possibly? Wouldn't that be fun!
