Hi all. I've used the WiModem 232 on an Apple IIC and a Macintosh Plus and would like to get my Atari 800 online but can't seem to get anything going. I use the Smart Term cartridge, an Atari modem cable, and the 850. When Smart Term loads, it gives me the menu. I select "T" for terminal mode. Then it shows "online", but I cannot type any characters. I've even used the modem cable to rig a connection to joystick port 1 and get the same thing. Not sure what else to do since information isn't easy to find. Any info would be appreciated. Thanks.
There is a Facebook group for the Atari 800 and there are people talking about what is required there for using the WiModem232. I don't recall what group it is, I find it originally by doing a search on Facebook for "WiModem232". Maybe if you also add "Atari" it might pop up immediately without having to scroll through the messages.
OK, here is a Facebook link:
https://www.facebook.com/photo.php?fbid=...UQ_xK8ZtXg
Keep in mind that whatever stored baud rate you had in the WiModem232 might be different from the terminal program you are using on the Atari 800.
(11-21-2018, 03:56 PM)admin Wrote: OK, here is a Facebook link:
Thanks for the info. Sorry I was so late in replying.
