Can’t connect, No Answer
Hi,
I just recently purchased the Wimodem232 for my Amiga 1200.  I was able to connect to my network, but am unable to connect to any server, even google.com:80.  I tried NComm and Term4.3 as my terminal software.  I tried the telnet translation setting, but that didn’t help.  Is there something else I am missing?  Thanks
If could be that you have v2.93 firmware and the network type is set to STATIC instead of DHCP.  Type: ATI4<RETURN> and see what the network type is.  If it says STATIC, then type: AT*NET=DHCP<RETURN>
Once you have done that, update the firmware to the latest version using the update feature:  AT*UPDATE<RETURN>
(08-20-2018, 10:39 AM)admin Wrote: If could be that you have v2.93 firmware and the network type is set to STATIC instead of DHCP.  Type: ATI4<RETURN> and see what the network type is.  If it says STATIC, then type: AT*NET=DHCP<RETURN>
That did the trick!  I never would have figured that out, thanks!
Sorry about that... my fault! I left the network type set to STATIC after adding that feature!
