08-15-2018, 04:29 PM
If you recently received a WiModem232 and you can't get anything to connect, go take a look at the network type using ATI4. If you see the network set as STATIC (and you didn't deliberately do that), you need to enter:
AT*NET=DHCP<RETURN>
There is a "bug" in the factory defaults that sets the network type to be STATIC instead of DHCP on a reset. I will fix that in the next firmware update.
AT*NET=DHCP<RETURN>
