Converting : Kryoflux Stream Image --> SCP Image
How to convert Kryoflux Stream Image to SCP Image?
First : Download latest version of pfi.exe from PCE (IBM PC) emulator binary file.
http://www.hampa.ch/pub/pce/pre/
Then run pfi.exe as follows on command prompt.
pfi track00.0.raw filename.scp
Kryoflux Stream image is now converted to filename.scp.
But you can see a few of Kryoflux Steams files are Not track00.0.raw ~ track 83.1.raw.
(Example : filename00.0.raw ~ filename83.1.raw)
In this case, you can download KFR.BAT (attached file) and run KFR.BAT to rename all files as track*.raw.
.zip   KFR.zip (Size: 857 bytes / Downloads: 9)
You can also use the HxC Floppy Drive Emulator software to convert various disk formats to/from .scp format.
