Here's my solution. I use a USB micro cable with on/off switch here:
https://www.amazon.com/gp/product/B00JU2...UTF8&psc=1
Then use a USB micro -> mini converter here:
https://www.amazon.com/gp/product/B002O1...UTF8&psc=1
Any better solutions out there?
I am using a rechargeable USB battery that has an on/of switch. I will be selling these shortly.
Threads: 6
I had an extra TP-LINK smart plug I wasn't using. My ridiculous solution was to configure it to work with my Alexa devices. So, I say "Alexa, turn off the modem". Heh, heh.
I find it highly amusing to use voice commands to control hardware that interfaces with my Apple //e.
Threads: 5
(01-23-2018, 12:35 PM)Byte Knight Wrote: Here's my solution. I use a USB micro cable with on/off switch here:
Thanks - you've given me the idea of getting a 2A inline lamp rocker switch. Then chop up the long mini USB cable I'm using. Then wire it up with the switch.
If I solder in some extra wire for length for the data wires as well - it can still be used as a data cable for something else.
