11-01-2016, 12:28 PM
hi sorry but i dont go into the cometchat after ........i connect with commodoreserver but after for exit what do you do go off c 64 ???
CommdoreServer V-1541 instructions
11-01-2016, 05:54 PM
You need to use the V1541 disk.
11-02-2016, 12:57 PM
11-02-2016, 01:57 PM
(11-02-2016, 12:57 PM)scanword Wrote:(11-01-2016, 05:54 PM)admin Wrote: You need to use the V1541 disk. ok now i have write $ and see the menu of commodore server but for use it ????(now i connected to commodore server ....) and i dont find v1541 ....but i dont understand sorry but i use ultimate cartridge 2 for use v 1541program but tell me when i must use it (when connecting to commodore server ofr other time ..........and if is possible thanks ....sorry but i not understand
11-02-2016, 08:53 PM
You need to got to CommdoreServer.com and read the information on how the V1541 disk is to be used.
11-03-2016, 11:13 AM
(11-02-2016, 08:53 PM)admin Wrote: You need to got to CommdoreServer.com and read the information on how the V1541 disk is to be used. hi, ok i have used the program v 1541 with comet 64 and with the load"cometchat" but i dont understand how to use with wimodem ok : i connect wi modem (she write ready ) than i connect to the commodore server ( she write connected ) but after i write $ and appair all menu of commodore server i dont know what to do for use this menu ...i cant write load (comet chat or other program )or other please help me or send me a mail of person that can help me thanks very much bye
11-03-2016, 12:44 PM
You have to connect to CommodoreServer.com first, then load V1541,8,1 do the SYS49152, and then load and run Comet Chat.
In the first page of this thread, there is a simple BASIC program that will help you.
11-03-2016, 12:48 PM
The steps to connect to Commodore Server.com are the same no matter what type of device you use (modem, WiModem, or RS232 interface):
Insert the V1541 disk. Type: LOAD"V1541",8,1<RETURN> When the load completes, type: NEW<RETURN> Now type: SYS49152<RETURN> Enter the following BASIC program: 10 OPEN2,2,2 20 PRINT#2,"ATDTCOMMODORESERVER.COM:1541" 30 CLOSE2 RUN this program. It will connect to CommodoreServer.com Now, type: LOAD"COMETCHAT",8<RETURN> RUN this program and you will be online with Comet Chat!
11-03-2016, 02:54 PM
ah ok now it work but the procedure is different for this item but no problem it is perfect .......now i must understant how to load directly the mini program ........thanks for the moment
11-03-2016, 04:32 PM
ok now i solved for little program ok thanks to all
« Next Oldest | Next Newest »
