Separate Joystick Board?
While waiting for the keycaps to get printed, I was wondering about how I will be able to connect my joysticks, is there a board I need to get?
There will be an add-on board. It replaces the plastic plug that blocks the two DB9 holes. The board plugs into the Razzle board using a 4 wire cable. This is of course for the BlingBox™, as the Blingboard64 does not have any way to attach joysticks.
Thanks for the info, I'll make sure I get one.  Wink
