03-16-2024, 12:48 PM
I have recently bought a WiModem232 Pro. I configured to log onto my wifi network.
That worked fine. However, every time I boot/restart the WiModem it logs onto that network automatically.
Since Im working on a program for an old 8-bit computer, I would like to test things out,
so for that I need to remove the SSID infos (user and pwd and ip address) from the modem that I allready
added using the AT*SSID command..
So basically I want a real factory reset, remove everything.
I tried different things. Like holding the reset button down for 10-30 seconds.
(It seemed to reset but did not remove all info).
I tried shutting down the wifi network and reset the WiModem using AT&F command.
None of these worked.
I read somewhere that one could do hardware modification, but the Pro version has this case
one has to remove?
I have not yet read the entire manual to find other things to try out.
But I thought to ask here meanwhile.
(The WiModem seems to be a great product so far).
Thanks.
one has to remove?
Thanks.
