step time
#11
No, they are not standard. They are special versions (ABT) that have low voltage thresholds. Return the board to me and I will repair it. I offer a lifetime warranty on all electronics I make.
#12
Thanks - since I no longer have the original packaging, is this correct?
CBMSTUFF
3269 Maracopa Ave. Ste 114-511
Lake Havasu City, AZ 86406
I have the original receipt from PayPal but they do not show an originating address.
Thank you, you're the best!
W1ARQ Howard
#13
Board on it's way.
W1ARQ Howard
#14
Yes, that's the correct address.  I will test it first to see if you have a drive issue or if there is really a problem with the board.  I have gotten a few boards back in the last month, and in all cases the board was fine and the drive (or cable) was the issue.
#15
ok - thanks, I did try several drives as I have many - 5.25 SSDD (190k), 5.25 DSDD (360k), 5.25 DSHD (1.2m), several 3.5 720k and 1.44m, and all were working when recovered, along with at least 3 different cables - all produced the same results of this last issue.
Also be advised that I included $10.00 for you for return shipping just in case you should miss it out of the box. I felt that you should not have to be out-of-pocket for return shipping.
Again, thanks a lot.
W1ARQ Howard
#16
Thanks, I will let you know what I find.
Users browsing this thread: 5 Guest(s)
