[SOLVED] ATUPDATE error
Hello,
The wimodem display is saying Update available but whenever I type atupdate the response is just error. I've done updates in the past so not sure what is going on. Is the update server online?
Thanks
(08-12-2018, 10:19 AM)tegmah Wrote: Hello,
Thanks
AT*UPDATE Smile
The Workshop -  http://home.reidspace.com/
Yep, you are missing the asterisk (*) between AT and UPDATE.
Thank you that worked! Smile
Can admin can update the firmware update page?
http://www.cbmstuff.com/forum/showthread.php?tid=313
The instructions say:
To update the firmware of your WiModem, connect to the internet via your router, launch a terminal program and type:
ATUPDATE<RETURN>
Actually, if you read the entire page it tells you that this has changed to AT*UPDATE.  However, I will add a note to the top of the page for those that don't like to scroll.  Wink
(08-12-2018, 07:36 PM)admin Wrote: Actually, if you read the entire page it tells you that this has changed to AT*UPDATE.  However, I will add a note to the top of the page for those that don't like to scroll.  Wink
Haha thanks, I did scroll but I guess I missed that part. Big Grin
