Threads: 13
Hi Jim
These are the commands as I'm sending them(in case it helps).
If I were to guess I would say that for whatever reason, the at*b38400 is failing, so the atdt connection string is not sent out.
Code:
ser_ioctl(1, NULL);
get_wimodem_status();
ser_put_str("at&k1");
ser_read_str(2000);
ser_put_str("at*r0");
ser_read_str(2000);
ser_put_str("at*c0");
ser_read_str(2000);
ser_put_str("at*d0");
ser_read_str(2000);
ser_put_str("at*b38400");
ser_unload();
if (cbm_load ("v-1541.38k", getcurrentdevice (), NULL) == 0) {
printf ("V-1541.38K failed to load\n");
return 0;
else {
printf ("V-1541.38K loaded ok\n");
__asm__ ("jsr %w",0xc000);
printf ("\n");
err = cbm_open("2","2","2","");
if (err != 0) {
printf("Could not open device 2. Error: %d \n",err);
else
printf("Device 2 opened ok.\n");
err = cbm_write(2,"atdt commodoreserver.com:1541\n",30);
if (err == -1) {
printf("Could not write to device 2. Error: %d \n",_oserror);
else
printf("Device 2 write ok.\n%d bytes written \n",err);
I have not tried this yet (I am away at a trade show). It should just work now that I added back support for the ATI command.
(01-05-2018, 01:29 PM)admin Wrote: I have not tried this yet (I am away at a trade show). It should just work now that I added back support for the ATI command.
hi tomorrow i have install new firmware 2.20 but the wimodem dont connect to commodore server the connection dont work without that manual not with csload 38 in automatic .... as he did before please tell me what do ok thanks bye
Commodore server appears to be down currently.
It's back up now!
The CSLoad doesn't connect to commodore server, and it doesn't show that it is trying to dial it either. However, I do see: "Device 2 opened ok" and "Device 2 write ok" messages. The formatting for the response messages changed with v2.0 firmware. Would this make a difference? I think I deleted a CR/LF.
(01-10-2018, 12:28 PM)admin Wrote: The CSLoad doesn't connect to commodore server, and it doesn't show that it is trying to dial it either. However, I do see: "Device 2 opened ok" and "Device 2 write ok" messages. The formatting for the response messages changed with v2.0 firmware. Would this make a difference? I think I deleted a CR/LF.
Hello thanks for the quick response I just wanted to tell you that I used the same procedure (program) that I used before (csload38) I found on your site cbm now I just do not understand if something is missing or I deleted something but I do not think .. ..beh let me know in the meantime tomorrow afternoon check also csload38 ok thanks hello
Threads: 13
Hi Jim
I dont see why it would..
But that raises another question. Are you expecting a CRLF at the end of the ATDT command ? I'm only sending a line feed (\n).
I'll try it with \r\n and see if that makes any difference.
(01-11-2018, 12:10 AM) pid=\2855' Wrote:[quote pid='2853' dateline='1515612507']
hi today i have donwloaded the csload38 (2) from workshop when i launch (run) with my ultimate 2 the c 64 stop to load and crash it or if i load and after i type run she write me 2400 baud driver load error ......................if you want i send you my 1541 file to control if ok but ......tell me ok bye thanks
[/quote]
Threads: 13
(01-11-2018, 10:01 AM)scanword Wrote: (01-11-2018, 12:10 AM)pid=\2855 Wrote:[quote pid='2853' dateline='1515612507']
[/quote]
Hi
csload38 needs to be able to load c64-up2400.ser for the same place as the prg file.
I'm not sure how ultimate2 works in that respect
(01-11-2018, 12:10 AM)Zeropage Wrote: (01-10-2018, 12:28 PM)admin Wrote: The CSLoad doesn't connect to commodore server, and it doesn't show that it is trying to dial it either. However, I do see: "Device 2 opened ok" and "Device 2 write ok" messages. The formatting for the response messages changed with v2.0 firmware. Would this make a difference? I think I deleted a CR/LF.
Hi Jim
No, I look for either /r or /n for the line termination.
It seems like the PRINT#2 that sends data to the modem is not being accepted, almost like the handshaking is not correct. I changed a LOT of things with v2.00, so I will look into that.
