Problem is I have a 1541-II drive, but no working C64. I might be able to get hold of my Chameleon 64 again though, which can make my C64 work.
I bought some cleaning alcohol and I am running the disk now.
I cannot find any good way of using SCP images with C64 emulators? I think another person had the same problem. I have downloaded the HxC Floppy Emulator, but it does not seem to help much since none of the formats it can export to are C64 emulator friendly as far as I can tell.
Did not seem to help. I did test some of the disks with my Chameleon 64. But so far nothing works whether I use splice or index. Well, one could actually load, but it was also a file of 5 blocks or less. I will try to get my Chameleon 64 back.
You should be able to just make a .g64 from the SCP software and use it in VICE. That's how it is suppose to work.
Email me your .scp image file and I can tell you what the problem is. Send it to: data@cbmstuff.com
Btw, I found this link suggesting how to make a cleaner disk for 5.25" floppy disk drives
http://www.retro-commodore.eu/2015/04/05...ning-disk/
I will send some of the images I made in .G64 format.
Hi all, and it does indeed work, but only for disks with the index pulse. I also wanted it to do any disk, such as my old development disks but I believe it needs a tool/converter to massage the data somewhat and I don't think that work is complete.
BTW, I also have a 1541-II and the top comes off very easily with a few screws exposing the head which can be carefully cleaned with IPA and cotton swabs. I ended up putting the top back on without the screws in, as it needed cleaning so regularly that I found I needed to lift the lid over and over. If you always switch it off and go carefully, cleaning the head is not hard this way - but if you're just not confident, get a cleaner disk.
