bad data packet crc-32
Im using the wimodem232 with amiga 3000.
Everything works fine except when I want to up or download files.
I get
Data packet too large Then
The term program is set at 19200  8n1
Serial port on the amiga is set for 19200 8n1  RTS/CTS  and buffer at 1024
Im using zmodem for transfers (but it does it with any protocol )
Modem is on current firmware  6.20   6/3/23
modem also reports 19200 8n1
What stupid simple thing am I missing?
Ive done this and no change
Problem: I connected to a BBS and when I start a download it immediately
starts having bad blocks and retries.
Solution: Make sure that the translation mode is set to 0 (AT*T0). This
turns off the Telnet translation.
Found a answer in another thread
https://www.cbmstuff.com/forum/showthrea...82#pid2882
Yes, you definitely need to set the translation mode to match what you are connecting to! Also don't forget that you need to enable the hardware handshaking using AT&K1.
