01-05-2023, 09:40 PM
Okay, is anyone using the WiModem232 at higher than 19.2k speeds?
I've got an Atari Mega ST4 which comes stock with a 19.2k serial port.
I' just installed a mod (RSVE) that enhances the standard ST serial port
so that it can go higher.
It uses the HSModem software that "remaps" the 19.2k speed to what
you set it too. In my case, that's 38400. So any legacy software that
can't be set to higher speeds will, even set to it's regular limit of 19.2k,
still use the higher speed. Or that's the theory anyway.
The mod comes with a red LED that lights up when the higher speeds
are being accessed. The mod does that here, so it should be working
correctly.
I can not get the RSVE equipped Mega ST4 to communicate with my
WiModem232 though. It's like there is a speed mismatch. Kinda like
when it comes setup at the initial 300 speed and you try to access it
from comms software but the commands won't go through until you
set you comms speed to 300 and then change it.
If I disable the RSVE mod and set the WiModem232 to 19.2k, then
everything works correctly again. I've tried pretty much everything
I know to do...
Anyone else have any advice, ideas or thoughts? Thanks much.
correctly.
I know to do...
