08-27-2022, 06:40 AM
Hey guys,
Been using my WiModem for a while now. I have it hooked up to my Atari & but system. It was working great. I ran the firmware update the other day. Seems to go through with no issue and worked afterwards. I came to use it yesterday I plugged it in and all I get is an lie light. Nothing on the screen. I does not appear to be booting up its os.
I did try the emergency reset. Still just the blue light. Tried my other WiModem (which is connected to my st. ) works fine on both power supplies and both systems. Both are model WiModem 232.
Do you think my modem is toast? I’d just thought I would check before I ordered a new one.
