Creating real Amiga disks from .SCP files
I have tried to make a copy of my protected Amiga disks. And I failed. I can create .SCP file which works in WinUAE emulator, but when it is written back to disk - does not work. Any ideas what am I doing wrong?
What disks? What mode (INDEX/SPLICE) are you using? If it works in WinUAE then all of the data is there!
I use Splice mode. I know that .scp file is okay, because it works in WinUAE. However, I cannot write it back properly to the diskette. Diskette created has proper name and some data, however, it cannot be loaded properly - Amiga says disk is corrupted.
It is likely due to the SPLCE mode not being able to determine where the write splice is. If the disk is indexed then INDEX mode would work. I responded to your PM.
