01-24-2021, 11:02 AM
Hello,
I'm trying to backup my original Test Drive for Apple II but it doesn't work.
The original boots fine, When copying with SCP software it doesn't work at all, I tried many drives, settings, disks, etc...
When I use a8rawconv, it's a bit better, the disk boots but at one point it stops. It's always at the same point that it stops btw.
I read in some posts that Jim suggested to do a manual track by track copy using the analyzer/editor.
Can someone explains the steps or the procedure to do that?
Thank you.
Pitou!
Thank you.
Pitou!
