09-06-2020, 08:39 AM
I have problems writing images to floppies. I have dumped some 360k floppies with SPC (under windows XP, using splice mode) and I'm trying to write those images on blank floppies. The writing process seems to work but then when I try to copy the content of the floppy on another computer I have systematic reading errors.
I dumped the copied floppy with SCP and the content is clearly not the same as the original so it's not writing properly (see file https://we.tl/t-kaT7wK6Wq8) :
I tried with 2 different floppy disk drive, 2 different cables and 2 different machines.
what could be the reason fot this problem ?
- multimate utils.scp is the original dumped copy
- utils-copy-splice.scp is the dump of the disk written using splice mode (SCP under windows xp)
- utils-hp-index.scp is the dump of the disk writtent on another machine (windows 10), using index mode.
