Cannot install SCP anymore, virus found
#11
The only DLL that I call is the FTDI driver, and that is signed. There is not much I can do about a VB6 app other than get a signing certificate.
What I don’t understand is that I don’t see an issue with any of my own Windows 10 setups, even after the latest update.
#12
I see an update checking menu in the application. So you are calling some network functions to do this, isn't it ?
#13
I am calling a system function, not a DLL to do that. The only DLL that I open is the FTDI2XX.DLL.
Unfortunately, I can't test any kind of changes because I don't have any machines that complain about the SCP.exe file. The online scanners that fail are all Android based, and you can't load a Windows .exe on an Android device, so those don't matter.
#14
I have just run into this problem myself with Windows Security in Windows 10.  I can not install the software or the dll.    Windows security strikes it as a virus.
#15
I can not install the software either.  Windows 10 1909 with just the default Windows security.
Threat detected: Trojan:Win32/Ymacco.AAF5
Alert level:  Severe
#16
You have a problem with the installer or running the app?
#17
(06-27-2020, 03:08 PM)admin Wrote: I am calling a system function, not a DLL to do that.  The only DLL that I open is the FTDI2XX.DLL.
Yes this is what i want to mean : You are using network related functions so your exe is for sure linked to a Windows dll to have access to these functions (Ws2_32.dll or something similar).
I don't see android related stuff on the VirusTotal screenshot i posted here yesterday.
#18
Go look at the websites that are reporting the false positives and you will find that most are for android devices.
#19
I can confirm that there are no issues installing the latest SCP on Windows 10 Enterprise 1909.
Perhaps the computers themselves have viruses?
It's certainly not SCP.
I attached a screenshot
Attached Files Thumbnail(s)
#20
Thanks for sharing!
Users browsing this thread: 5 Guest(s)
