Apple IIe/IIc/IIgs setups
#41
Wow! That's a good find! I can't imagine why they would have AT&F there, because that would definitely reset a real modem too.
#42
Hey all, just had a quick question. I just purchased a super serial card for my apple iie platinum, and was wondering about the serial cable. do I use a straight-thru cable or a null modem cable?
#43
(06-24-2022, 10:42 AM)DanW Wrote: Hey all, just had a quick question. I just purchased a super serial card for my apple iie platinum, and was wondering about the serial cable. do I use a straight-thru cable or a null modem cable?
It depends on what is on the other end of the cable........
A null modem cable would be if you are attaching it to another computer directly serial port to serial port.
I've never heard them referred to as straight through cables before.
I thought they are referred to as simply a serial cable or modem cable, but I never pinned one out before either....
#44
It would be connected to a wimodem232
#45
>DanW
Then start with the straight thru cable
If that doesn't work try this
SSC -------------------------- Modem
GND 1  ----------------- 1  GND  frame ground (this line is OPTIONAL)
TXD 2  ----------------> 2  TXD  transmit data (from SSC to modem)
RXD 3  <---------------- 3  RXD  receive data (from modem to SSC)
RTS 4  ----------------> 4  RTS  request to send (for hardware handshaking)
CTS 5  <---------------- 5  CTS  clear to send (for hardware handshaking)
DSR 6  <---------------- 8  DCD  data carrier detect (from modem)
GND 7  ----------------- 7  GND  signal ground (for all signals but pin 1)
DCD 8 (leave unconnected!)
DTR 20 ----------------> 20 DTR  data terminal ready (to hangup modem)
Have the ends of this cable labelled "SSC" and "Modem", as it will not work correctly if plugged in backwards
#46
(06-25-2022, 12:10 AM)neal@layton.org Wrote: >DanW
Gracias. One more question: do I set the super serial card to "terminal" or "modem"?
#47
modem
#48
I have used a standard RS232 modem cable as well as just a gender changer (direct plug-in) with my SSC on the //e.
Users browsing this thread: 5 Guest(s)
