05-20-2017, 11:43 AM
Just a thought guys.I figured why re-invent the wheel.Just create a user port to serial port adapter on the Amiga.Hope Jim Drew is watching..Thanks for the Wimodem..works like a charm..
Wimodem amiga adapter
05-20-2017, 12:13 PM
You can't just use an adapter. The Amiga and other machines use true RS-232 voltage levels (+12/-12v). The C64/128 uses 5v/0v for communications.
I have made a new version that plugs directly into a DB25 connector. It has a nice case and a 2.1mm plug for a 5v source (wall wart or plug to be wired to 5v from somewhere inside your computer).
05-28-2017, 05:37 AM
(05-20-2017, 12:13 PM)admin Wrote: You can't just use an adapter. The Amiga and other machines use true RS-232 voltage levels (+12/-12v). The C64/128 uses 5v/0v for communications. Hope to see it on the market.I'd definately get one.What speeds do you get?
05-28-2017, 09:34 AM
115200 is no problem with baudbandit.device with a stock A500. I might modify my empser.device that I wrote for EMPLANT so it works with the internal serial port and see if I can get it to go faster.
05-30-2017, 11:33 AM
(05-28-2017, 09:34 AM)admin Wrote: 115200 is no problem with baudbandit.device with a stock A500. I might modify my empser.device that I wrote for EMPLANT so it works with the internal serial port and see if I can get it to go faster.The only other extra I would add would be a port passthrough for tablets and such.
05-30-2017, 04:13 PM
There is no pass-thru. The serial port can only have one device on it at a time (pin load restrictions).
05-31-2017, 08:27 PM
05-31-2017, 08:40 PM
Serial ports are typically DB-25 connectors, with a single serial port supported. There is no such thing as channel 0 and 1.
06-01-2017, 05:27 AM
Let me rephrase that..I meant ports not channels....I use port 0 currently on my Wiz tablet.So yes there is port 0 and 1.
06-01-2017, 08:05 AM
So, you have two different serial ports - no need for a pass-through!
« Next Oldest | Next Newest »
