Beta .97
- Fixed problem image file creation that was introduced in v0.96.
Beta .98
- Fixed problem .g64 image file creation with new image file format.
- Increased buffer size from 64MB to 100MB to allow for huge flux images. I need to change this buffer size to be based on the number of revolutions, instead of hard coding it!
Beta .99
- Changed the analyzer's MFM display back to MFM... it was showing FM as a test I was doing and I forgot to switch it back.
Release v1.00
- Fixed buffer length issue when switching between MFM and Flux data.
- Reset frame name when switching between drive and images.
- Enabled disk utilities.
- Made one ReadTrack() routine that is shared with the analyzer and disk utilities.
- Made one WriteTrack() routine that is shared with the analyzer and disk utilities.
- Corrected problem with strongbits (no flux area) highlighting in the analyzer window.
- Added new firmware code to be able to disable/enable the auto shutoff routine and made some corrections to several parameter setting routines.
- Removed the wording "BETA" and made it the official release.
Note: v1.00
requires the v0.7 firmware upgrade.
Release v1.01
- Changed Flux Display so it shows flux data as time based instead of bitcell based. This gives us the ability to see strongbits (no flux areas), marked with a red pixel (typically forming a line) at the bottom of the display.
- Changed firmware to fix issue with reading tracks that are 100% completely no flux areas.
- Changed red vertical stripes in flux display to gray, and now show the proper sections for each revolution.
- Added framework in Flux Display to allow showing any revolution individually or sequentially, with different colors.
- Increased speed of Flux Display refresh.
- Changed firmware to allow a no flux area to appear at the beginning of the revolution.
Note: v1.01 and later
requires the v0.8 firmware upgrade.
Release v1.02
- Fixed crash in Flux Display with NFA in certain conditions.
Release v1.03
- Fixed problem with scroll bar in analyzer when less than one screen's worth of data, causing a crash if the scroll bar was moved.
- Disabled flux display options until those features are completed.
Release v1.04
- Added ability to set the number of revolutions used when creating a disk. This lets you use the 1st or 1st/2nd revolutions (if necessary) with a multi-rev image file to quickly make a copy. Now when you click on the Override file option, the number of revs will be available to change and will be used during the copy.
- Split making a disk from an image file into two steps:1) loading the flux image, 2) making the disk. This allows for a better control for override options, but more importantly this will give us a way to analyze and display flux images before making a copy (in a future version).
- Fixed issue with analyzer not displaying 1.44MB MFM data correctly.
- Got rid of the FLUX, MFM, and GCR buttons. Replaced these with a dropdown list instead with FLUX, MFM, FM, and GCR options.
- Added ability to display RAW or HEX data. HEX data will decode MFM or FM data into hex.
- Added support for the numeric keypad numbers... for that picky French guy!
Release v1.05
- Added FM mode to analyzer.
- Fixed problem with analyzer's speed correction.
- Changed first entry to be ignored in the flux display's minimum bitcell time.
- Added support to analyzer for displaying MFM data as decoded hex.
- Added support to analyzer for SYNC option with MFM disks.
- Added support to analyzer for strongbits (no flux areas) in MFM data.
- Added ability in analyzer to disable re-seeking to track 0 during reads.
Release v1.06
- Changed OFFSET in analyzer to default as unchecked.
- Added OFFSET for MFM and FM modes in analyzer.
- Changed flux display to show information for each revolution in the tooltips, for multi-revolution READs.
- Fixed bug in calculating write splice for multi-rev images. This bug was introduced with the support for NFA.
- Fixed a few button combination issues in the copier.
- Improved copier interface! Now fills in start/end track/heads based on the disk type, which is now a pull-down list with many types of disks listed. New Copy Mode feature lets you select Index or Splice (and soon DOS will be added). Colorized track display, and more!
- Swapped Copier and Analyzer positions in the Function pull-down menu.
- Removed G64 file unless disk type is set to C64/128.
A new manual was released to cover the new additions and changes.
