06-17-2018, 11:04 AM
I'm just curious what your suggestion might be then? I have other RS232 interfaces that work fine in 128 mode, under GEOS and Wheels.
Disabling UP9600 hack for use with C128
06-17-2018, 07:24 PM
Did you cut the other jumpers? If that doesn't work then it would be a problem with the software and the only solution would be to unplug the WiModem. The situations I have seen are when the program accidentally uses the user port lines.
01-18-2021, 03:05 PM
I'm trying to understand the UP9600 (hack). I've cut the jumper on my WiModem so I can use it with my C128D. Everything seems to operate fine at 2400baud. It also, seem to be ok at 4800 baud. Even with Desterm I've been able to connect at 9600 and it seems ok.
Some terminals give me all sorts of weirdness after 2400 baud. I'm just trying to understand what's happening and why 2400 is the upper limit with that jumper cut. But is it? 9600 is working in some cases and it is clearly faster.
01-18-2021, 07:14 PM
The UP9600 hack is strictly for the C64 (or C64 mode). You can use up to 9600 baud in C128 mode without any “hack” required.
« Next Oldest | Next Newest »
