Request for +3/CPC disk type
Since this is the Sinclair section...
Could I request a new disk type/selection for Spectrum +3 and Amstrad CPC disks?  They're single-sided double-density disks, with 40 normal tracks (allow up to 42), and the head is single-stepped between tracks.  They're flippy disks, but the original drives only support accessing a single side at a time.
None of the existing disk types match these requirements.  So far the only option seems to be to dump it as a double-sided disk, which doubles the file size and time to create each image.
This area is for discussing Simclair emulations. The SuperCard Pro section has info on copying Amstrad CPC 3" disks.
