11-26-2015, 10:13 PM
Hi Jim,
Just got my new SCP, thanks. 8-)
I have the SCP connected to both a 3.5in floppy as drv 0 and a 5.25 96tpi drive at srv 1. Seems to all be working great 8-)
I am going to be Archiving all of my disks to Flux images over the next few months.
I have a about 300 Amiga Floppies, 60 C64/C128 Floppies and around 40 IBM PC Floppies to image. Around 30% are original Program Disks, the rest are Data or work disks or prog copies..
From reading through the forums I think i have worked out what I need to do is.
For original Software (Purchased) Disks of any of the Disk types, I should select INDEX Mode
For all my other disks written on my local machines I should use SPLICE mode set to 2 or 3 revolutions?
Is that correct?
Also couple of other questions if you don't mind
Why is there no selection for 1.2Mb IBM Floppy?
Do I need to do anything special when moving through the 4 different Commodore 8 bit type disks? That is I have 1541 SS, 1541 Notched Flippy's, 1571 DS, C64 CP/M Cart Disks) and C128 CPM Disks.
I have a few SFD 1001 disks too, what setting would you suggest for those?
Are there posts explaining what I am seeing with the Flux Display and Disk Layout pagers in the analyzer?
I apologize for all the questions, but its all new stuff to me. 8-)
Thanks so much for your help and a great product. 8-)
Is that correct?
Regards...GeoKM
ooooOOOOoooo
ooooOOOOoooo
