Sugarbox supports SuperCard Pro .scp image files directly! Just select the image file of your favorite 3" disk and use it like it was a real floppy!
Sugarbox can be found here:
http://sugarbox.free.fr/
Threads: 3
04-26-2018, 01:20 AM
(This post was last modified: 05-03-2018, 12:01 AM by Kris.)
In addition, Sugarbox allow you to create .DSK to .SCP file so that you can re-create almost any 3" disks.
Edit: I wrote "almost 3" disk"s because those which are using a very precise Index timing won't work with the SCP.
Thanks for the info, that's good to know!
