hi
when we make a physical disk from flux image file,
can we have a verification process (write, read, compare) ?
thanks in advance
philippe
You can always write a disk back. I don't know when/if there will be a write verification added. As long as the disk is good (which you can test with the media integrity tester), the writing should be good.
i have a 3" Amstrad FD-1 connected to the scp
when i test a disk it's always wrong at each track,
but writing flux on it is good ?!?
I don't have a 3" CPC drive/disks for testing. Are you saying that the media integrity tests fails on every track, but copies work fine? If so, can you run the media integrity test on a few tracks, and then make an image of that disk and upload it to data @ cbmstuff.com? I would like to see why it is failing. Have you cleaned your disk drive's head recently? A dirty head could be a reason for this.
