Threads: 10
06-12-2014, 08:20 PM
(This post was last modified: 06-12-2014, 08:21 PM by videofx.)
I have tried both index and splice and 5 different brand new floppy disks and get the same error when I try to run the copy. I get READ ERROR ON DISK BLOCK 1457
I know the disk is copy protected because when I make a disk from an ADF and run install it keeps asking to insert DISK 1
Please help as this disk is NOT available anywhere should something happen to my original
Oh and I'm running version 1.20 and firmware .90
Threads: 10
I thought that going out further might fix the problem so I changed it to go to track 81 head 1 and still same error when I try to install from the copied disk.
Send me an image file made with a SPLICE to data @ cbmstuff.com
Threads: 10
Thanks! File is on it's way!
(06-12-2014, 08:44 PM)admin Wrote: Send me an image file made with a SPLICE to data @ cbmstuff.com
Threads: 10
Also sent you splice image for my Composite Studio Pro 2 disk. Backup doesn't work but original does.
Thanks for your help!
I will look at these tomorrow!
(06-12-2014, 11:32 PM)admin Wrote: I will look at these tomorrow!
Jim,
What was the outcome of this ?
It was resolved via email.
(07-21-2014, 08:29 PM)admin Wrote: It was resolved via email.
Jim, may I assume that it was a user action that solved the issue and resulted in a successful backup after all?
I don't recall exact what the issue was, I will check my emails when I get to my office.
