07-05-2026, 10:06 AM
(This post was last modified: 07-06-2026, 01:54 PM by FujiMan.)
Hi,
SCP setup with unmodified SD-700/SD-Combo (96 tpi)
Guitar Wizard Baudville (Side A-Commodore (timing hole) Side B- Atari - No timing hole) Single density
Interested in both sides, Atari first.
I've quite of few settings in SCP, even opening the disk jacket and flipping the media inside (so I'd have the timing hole)
I cannot get the copy to work (BOOT ERROR).
Need help.
Flipping the disk over is the only way to read the Atari side. I will have to look at this because I don't know much about Atari 8 bit disks. Your best best would be to use a8RawConv, which is a program that can use the SCP hardware to read/write Atari and Apple 8 bit disks. It also uses .scp image files. It was specifically made for SuperCard Pro image files then the guy opted to control the hardware directly.
https://forums.atariage.com/topic/231835...n-utility/
(07-05-2026, 10:15 PM)admin Wrote: Flipping the disk over is the only way to read the Atari side. I will have to look at this because I don't know much about Atari 8 bit disks. Your best best would be to use a8RawConv, which is a program that can use the SCP hardware to read/write Atari and Apple 8 bit disks. It also uses .scp image files. It was specifically made for SuperCard Pro image files then the guy opted to control the hardware directly.
Thank you. I just tried it and worked. It took a while to figure out what else was needed to get it to work.
I had to install the driver for the SCP and configure it for a virtual port.
PITA, but very happy that I now have a few backups.
I now wish there was a complete GUI for it.
