WiModem232Pro
Hello everyone, i just had the WiModem232Pro from the post man and i'm in need to download the manual for the setup. Now, since the website is on maintenance i can't download the manual as per provided instructions so my question is : will the manual of the old version works i mean, the AT commands are the same ? Nothing complicated but setting up the wifi network, the baud rate , the telnet ? I think the basic AT commands "should" be the same and, if i'm correct, i do have a .pdf of the old manual so i'm set.
Thanks in advance, Adriano .
Yes, the commands are the same between all versions (even C64).
