05-19-2025, 07:41 AM
Hi.
When accessing a server in the local network using telnet, I get TERM set to "wimodem", which makes programs confused about the features supported. Is there a register somewhere this string is stored so I can have "vt100", "ansi" or other configuration string compatible with the software running on the computer (or the physical terminal) attached to the modem? I can use my .profile script to force TERM to be something else if I login with it set to "wimodem", but it'd be cool if that could be configured on the modem itself.
Cheers, and, again, thanks for the amazing product.
