Error when updating pre-pro WiModem232
Hi everyone,
I recently pulled my WiModem232 out of storage, it is the OLED display model that says v3.1 in the corner, to start using again after a recent move.   I was able to connect it all up, connect to the Wi-FI, but when I try to run AT*UPDATE I get
"Process failed! - Wrong HTTP Code"
before it just resets back to connecting the router.  I know it's been a bit since I've used it, but not sure what to do to get this to install?
Thanks all!
Josh
I moved the server recently but did not enable the forwarding link. Try it again and let me know if it works.
