Besides the WiBridge program, there is another recently developed tool for doing file transfers:
https://github.com/arttu76/xfer
There is support for Windows, Mac, and Linux too!
Whats the secrete to get this to work? I have it on my PC Computer and running. NO Firewalls blocking. I go to my commodore and do the atdt PCIP:port number. terminal shows dialing and no answer
(01-14-2025, 05:06 PM)shawn.henson73@gmail.com Wrote: Whats the secrete to get this to work? I have it on my PC Computer and running. NO Firewalls blocking. I go to my commodore and do the atdt PCIP:port number. terminal shows dialing and no answer
figured it out The program was saying 1 IP but my computer is was not that IP.
Threads: 6
Trying to make this work. I am able to connect, once I select a file and hit Y I get "Waiting for client to start XMODEM protocol...", even though I start the transfer on the C64 nothing happens. Both machines just sit there. Using CCGMS.
Are you using X-modem or X-modem CRC? I think this requires the CRC version. I did not try this with CCGMS.
Threads: 6
(12-30-2025, 12:18 PM)admin Wrote: Are you using X-modem or X-modem CRC? I think this requires the CRC version. I did not try this with CCGMS.
I tried both...but usually Xmodem is initiated from the sender, no? You set up the receiver to receive mode, but it typically waits for the start bytes. I could be wrong. Either way, it just sits there.
Threads: 6
(12-30-2025, 03:02 PM)Digital Man Wrote: (12-30-2025, 12:18 PM)admin Wrote: Are you using X-modem or X-modem CRC? I think this requires the CRC version. I did not try this with CCGMS.
Well I don't know what changed...I reset everything and tried again and it's working. IDK!?
Maybe a router difference? Glad its working!
