5 hours ago
I re-read your post. ATV1 is not the same as AT*V1, which is the verbose mode.
I experimented for an hour or so with the original WiModem for the C64, WiModem232 V1, WiModem232 V2, and the WiModem232 Pro. I don't ever see a case where a LF is issued when doing the dialing. Anything that actually sends a response code CAN have a LF after the CR, depending on the Hayes command protocol for that particular function. Perhaps you are confusing commands that do not return a response (like dialing) vs. those that do?
