can't make connection to wimodem232 - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: WiModem232 / WiModem232 Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=79) +--- Thread: can't make connection to wimodem232 (/showthread.php?tid=786) |
can't make connection to wimodem232 - DanW - 01-17-2021 Hello, I tried posting this thread earlier but it never showed up so I am trying again. I am using an IBM Aptiva running MS-DOS 6.22, and recently bought the WiModem232 with OLED screen. I have it connected to the serial port via a serial cable and 9pin to 25 pin adapter. When I try running a terminal program such as Telemate, Telix, Kermit, etc., when they load i am unable to type anything. when I try setting the com port to 1 in telix and telemate I get an error telling me it can't initialize that port, only com2. in Kermit I don't get an error when I set the port to port 1 but I am unable to type anything. Any help would be much appreciated. RE: can't make connection to wimodem232 - admin - 01-18-2021 Sorry, but first posts have to be manually approved and then you can post anytime you like there after. See your original post for the response. |
