Emulation support scp - Printable Version +- CBMSTUFF FORUM (https://www.cbmstuff.com/forum) +-- Forum: CBMSTUFF PRODUCTS (https://www.cbmstuff.com/forum/forumdisplay.php?fid=1) +--- Forum: SuperCard Pro (https://www.cbmstuff.com/forum/forumdisplay.php?fid=3) +---- Forum: Amstrad (https://www.cbmstuff.com/forum/forumdisplay.php?fid=70) +---- Thread: Emulation support scp (/showthread.php?tid=175) |
Emulation support scp - giants - 07-06-2014 blup a lot of advertising for this emulator http://sugarbox.free.fr What’s new on this release (mainly focused on the FDC) : - FDC rewritten from scratch. It support now bitstream format, such as Kryoflux RAW or Supercard Pro. Paradigm is also improved to support MFM format (dsk files are re-converted into MFM format). This will offer a true support for complex disk and protection format. For example, overlap protection (« Reussir ») is passed with scp or kryoflux disks. - EDSK handling also rewritten from scratch. It add a new interpolation, to rebuild the original MFM track. Overlap and iterlaced sector are handled. - IPF and CT-RAW files supported through the CAPSLib 5.1 (included ) - Current disk can be saved as SuperCard Pro file - LED colors can be configured through config file - Insert blank disk DATA / VENDOR added - Scanlines are enabled if ‘=1′ in the Sugarbox.ini (more logical !) - B drive support - Current sector display added - « About » updated (at last !) - F3 = toggle 100% / MAX - Fix a little bug in sound bar, that prevent putting it near 0 - Now working (this is not a complete list !) : RE: Emulation support scp - admin - 07-07-2014 Neat... I will check this out. I have never seen a Amstrad CPC system before. It's nice to see the SuperCard Pro support. RE: Emulation support scp - giants - 07-07-2014 Maybe to buy it from ebay ? I think, 15 or 30€ you have it ![]() It's a good computer (after Amiga off course) LOL RE: Emulation support scp - Kris - 07-07-2014 It could be intersting that you discovered this nice CPU; it is very well known in Europe and a lot of potential SCP user are here
RE: Emulation support scp - admin - 07-07-2014 I have looked on eBay, and I have not found anything that was not 399 euros! RE: Emulation support scp - giants - 07-07-2014 Noooo, impossible ! See, in ebay france : http://www.ebay.fr/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xcpc+6128&_nkw=cpc+6128&_sacat=0&_from=R40 30€ (cpc 6128 + 10 discs) 50€ (cpc6128 + monitor + disc ++) .. Where do you leave ? if you want a CPC6128 and you can't find it on your local Ebay it's possible for me to buy for you (like 30€) + adaptateur video (if you don't have a amstrad monitor) Power for Amstrad CPC6128 (which is 3p floppy model) is done by the amstrad monitor 5v DC for the computer 12v DC for the floppy monitor with this 2 power alimentation are : CTM640 et CTM644 But, I think To heavy and so expensive Connectique exemple : http://www.amstradtoday.com/confort/moniteur.htm I have already send a Amstrad CPC6128 + Color Monitor from FRANCE to CORSE :=)) RE: Emulation support scp - admin - 07-07-2014 I am in the U.S., so I am not sure how a Amstrad would work with NTSC video systems and 110v. RE: Emulation support scp - Kris - 07-07-2014 To power supply the keyboard, you just need 5V & 12V (floppy)- 1.2 A so any transformer can do the job ![]() About video signals, the output is RVB ans should be usable on NTSC monitor. More info here: http://www.grimware.org/doku.php RE: Emulation support scp - giants - 07-08-2014 exact , I confirm. Or you can buy too a 110V to 200V, it's not expensive. As you want ! |
