Threads: 3
I have seen online that command-T will allow users to enter Terminal Mode in ProTERM 3.1 and go "online" with a direct terminal connection to the modem port to issue strings directly to the Wiimodem232. Once I am done, though, how do I exit this mode and go "offline" again?
I think you use command-T again to exit.
Threads: 3
(09-13-2022, 12:23 AM)admin Wrote: I think you use command-T again to exit.
That doesn't seem to work on my IIGS. I stay stuck in Terminal Mode.
You might want to look at the ProTerm3.1 manual. The IIgs uses a different keyboard arrangement because it has more keys.
Threads: 3
(09-13-2022, 10:46 AM)admin Wrote: You might want to look at the ProTerm3.1 manual. The IIgs uses a different keyboard arrangement because it has more keys.
The manual doesn't seem to acknowledge the existence of the terminal mode.
Well, that's not true.
Do a search on "terminal mode" and you will find dozens of references to it.
Here is a link to the original and v3.1 manuals:
http://www.applearchives.com/software/in...-apple-ii/
HOLDING the Option (Apple) key for 3 seconds will invoke the pop-up menu where you can change modes.
