CP/M disks
#11
Send me a image and I can tell you if the disk is indexed or not. You can send it to data (@) cbmstuff.com.
Make the image with blind mode unchecked.
#12
(02-18-2014, 07:26 AM)admin Wrote: Send me a image and I can tell you if the disk is indexed or not. You can send it to data (@) cbmstuff.com.
Here's what worked: I used a 48tpi drive instead of the 96tpi. I forgot to change the setting for 96 to 48 in the GUI.
Also, using Anadisk on the original in a 96tpi drive, shows interleave at 2:1, checking the copy (the one made in the 96tpi drive) shows interleave of 3:1. Also the original has sector id's 3,4,2,5 the copy has 1,2,3,4,5 both on side 0.
#13
OK, so there is probably an alignment issue with the 96tpi drive... or more likely you need two steps per track (ala C64), which is what a 48 tpi drive would give you automatically. I need to figure out an easier way to define all of the possible parameters.
