WiModem232 and Apple IIgs
I just purchased the WiModem232 and I'm trying to use it with the modem port built into the machine. I have the WiModem232 connected to a DIN-8 -> 25PIN serial cable on the modem port. When trying to connect to the modem using ProTerm, the modem is not recognized.
I fiddled around with the control panel settings and the modem settings in the terminal app and I still can't get it to be recognized.
If anyone has some suggestions as to what I should check and/or try, please let me know.
Thank you!
Keith Sheehan
Did you look at this thread? https://www.cbmstuff.com/forum/showthread.php?tid=477
(04-24-2020, 12:10 AM)admin Wrote: Did you look at this thread?  https://www.cbmstuff.com/forum/showthread.php?tid=477
That did it! Thanks!
One other question, how does one get color ANSI graphics when connecting to a board from ProTerm?
Glad that worked!
Sorry, I don't know about your ANSI question. I have only seen B&W out of ProTerm.
