WHD Program
I had no idea this had been realeased... Blush  Tongue
I downloaded and had a play.
After I sys49152 I get the "WHD installed ! " message no problem.
But if I try to "Load "$",7" it says "Loading" and stops .
I suspect this may be because I have a Jiffydos rom installed on My turbo chameleon. I'll disable it at some point today when I get a chance and try again.
The Workshop -  http://home.reidspace.com/
WHD requires that the baud rate be set to 9600 baud and that hardware handshaking is enabled (AT&K1). Go to a terminal program and type: at!$ to see if the directory shows.
I use JiffyDOS, but I don't use a Turbo Chameleon.
Yeah, I can get the directory in CCGMS. First thing I tried.
So, the baud rate is set to 9600 baud with hand shaking enabled?
I have the some problems..
how to fix this?
load "$",7 freeze ....
at ccgms directory works with at!dir
I will look into this.
Thanks...
and by the way: with the enable-speed mode at a scpu the detecting of the wifi modem doesnt work.
i have to switch off speed-mode before i type sys49152.
I am sure that is the case.  The code is hard coded (timed) for a stock NTSC (only) C64.  This won't work on PAL machines either.
