Problem with Commodore disks
Hi Jim,
I have a Panasonic JU-475-4APJ that was flippy modded by sncboom2k.
I cannot get a single image to work using my Supercard Pro, no matter what I change the setting to.
I am using the same drive with a KFlux card and have no issues.
I literally just unplug the KF, make no changes, then plug in the SCP.
KF image works, SCP doesn't
I am imaging Commodore 64 disks
What am I doing wrong????
Attached Files Thumbnail(s)
What disks are you trying to image? If they are commercial, you should be using INDEX mode. Otherwise, data disks have to be copied/imaged with SPLICE mode.
(03-02-2019, 12:50 AM)admin Wrote: What disks are you trying to image?  If they are commercial, you should be using INDEX mode.  Otherwise, data disks have to be copied/imaged with SPLICE mode.
Thanks for the reply, they are commercial, orignal disks.
I can backup most of them with nibtools etc, but have never mamaged to get a single working image from SCP.
It must be something I am doing wrong, or my card is dead?!
Good question.  Run the media test in the Disk Utilities Menu.  That will read/write to a disk and test the drive and SCP hardware.   It could be something as simple as your disk drive heads are dirty.
You can make an image file (.scp) of a disk using INDEX mode and send it to me (data @ cbmstuff.com).  I can look at the image file and tell you what is wrong.
(03-03-2019, 08:53 PM)admin Wrote: Good question.  Run the media test in the Disk Utilities Menu.  That will read/write to a disk and test the drive and SCP hardware.   It could be something as simple as your disk drive heads are dirty.
OK, I will do that and send you an image.
Thank you.
Thumbs Up
Image sent as requested
Thank you.
More images sent for evaluation.
Yep, your SuperCard Pro is bad. Take a hires picture of the board - in particular of the area with the Huey and Duey chips. I am guessing that you plugged the cable in backwards (probably to the disk drive) at some point and damaged Huey.
