Ready to test Amiga
I have plenty of non game apps that are copy protected that we can use to test.
So please let me know when we are ready to test.
The testing is technically over - we won. Smile
You can duplicate Amiga disks, as well as make image files.
Great so what do I need to make copies of my Amiga disks? I can do this today?
(12-16-2013, 07:45 PM)admin Wrote: The testing is technically over - we won. Smile
You just need the SuperCard Pro, a PC 1.44MB disk drive, drive cable, and female to female power cable if you want to power it via the SuperCard Pro - or an external power supply to power the drive separately.
OK, How do I get the Super Card Pro?
Where do I get the software to copy my Amiga disks?
(12-17-2013, 10:04 AM)admin Wrote: You just need the SuperCard Pro, a PC 1.44MB disk drive, drive cable, and female to female power cable if you want to power it via the SuperCard Pro - or an external power supply to power the drive separately.
You can order SuperCard Pro from our online store. The PC software installer is available here in our forums area: https://www.cbmstuff.com/forum/showthread.php?tid=6
I have looked everywhere but can't find the online store. Is there a link so I can order a card?
(12-17-2013, 10:30 AM)admin Wrote: You can order SuperCard Pro from our online store. The PC software installer is available here in our forums area: https://www.cbmstuff.com/forum/showthread.php?tid=6
Select STORE
Thanks I will be ordering the board as soon as I figure out how to copy my disks.
I installed the SCP software. Source is Flux Image File and Target is Flux image file. So how do I make a copy of my Amiga disk?
#10
You must have the SuperCard Pro board, a standard PC 1.44MB floppy drive, and a power source (which can be just a female to female 3.5" drive cable connected to the SuperCard Pro board). Without the hardware, you don't the option for selecting a floppy drive.
I will be putting the user manual online tomorrow, which shows the various setups.
