Threads: 148
A new version of a8rawconv is available that now allows for reading/writing DO/DSK and NIB image files using the SuperCard Pro hardware directly!
See here:
http://atariage.com/forums/topic/231835-...n-utility/
Threads: 3
(09-03-2015, 10:09 AM)admin Wrote: A new version of a8rawconv is available that now allows for reading/writing DO/DSK and NIB image files using the SuperCard Pro hardware directly!
See here:
Yes been trying to use this for a while for the past few days.
I downloaded the apple_gsos_versions.zip file from https://www.macintoshrepository.org/2003...apple-iigs
when you unzip there is a file called GS System 6.0.1.zip that has a bunch of dsk images.
apple_gsos_versions.zip (6.1 MiB / 6.4 MB)
GS/OS 1.0, 1.1, 3.1, 3.2, 4.0, 5.0.2, 5.0.3, 5.0.4, 6.0.1 / System disks for Apple II GS / Zipped
When trying to use a8rawconv-0.92 I get a error:
Unable to determine input format from input path:
I have reached out to them to ask what is goign on, but my question to you is how can I use your SuperCard Pro software to write .dsk files back to floppy?
I tried using HxCFloppyEmulator.exe to convert them to .SCP but no go.
By the way, I do so LOVE the SuperCard Pro.
I so far used it on my C-64, Amiga, Apple Mac LCIII and now trying to get it for my Apple //gs disks!! Atart ST is next on the list!!
Threads: 148
You need something to convert from .dsk to .scp. a8RawConv is what you should be using, so contact the author for info on your issue. I have never seen that error before using it.
